Defect Removal Efficiency, Test Efficiency & Defect leakage Gadgets
rajesh meka
August 20, 2018 edited
Is there any gadgets in JIRA where I get the Defect Removal Efficiency, Test Efficiency & Defect leakage Gadgets percentages and charts.
Also let me know any plugins available for the same.
DRE =
(Total defects found in development [A]/ (Total defects found in development[A] + Defects found in production [B] )) x 100
Defect Leakage=(No. of Defects raise by customer after release/No. of Defects raised by Tester before release-No. of invalid Defects from Defects raised by tester before release)*100
Test Efficiency
test metrics - effectiveness using defect containment efficiency
Rajesh Meka
5 comments
Troy Spetz
We use JIRA 7.12 server version.
The gadget catalogue in JIRA is quite limited (and in my experience) has not been extended in many years. I am not aware of any existing gadget which can perform calculations.
We also do not have a licensed add-on to perform the calculations you want.
The simplest approach would be to run a JQL query which gives you the total issues per category (e.g. internally- vs. externally-identified defects) and then perform the calculation manually.
gvantsa davitaia April 29, 2020
I have the same issue for now, have you found any solutions?
Thank you in advance,
Gvantsa
Vishal Goyal
August 17, 2021
If you were able to pull in required data for these metrics into a tool like Power BI or any other DB using APIs, it should be possible to write DAX / SQL queries to get the relevant metrics. Right ?
Have not tried it and will look into this.
ligia.gaspar91
December 7, 2021
Any news on this topic? I am looking for some plugin that would help with this
Holly Kozminski
February 23, 2022
Like • 2 people like this
Swagat Mishra December 21, 2021
For DRE, Is there any way to get the data through JIRA API and calculate outside JIRA system?
Sonali Sarkar
May 31, 2023
How to show the defect leakage % in Jira dashboard for multiple projects together?
