×Hi folks,
I gotta question about the cycle time feature on Jira. As we know cycle time is to measure team performance on delivering project or epic, similarly,the Cycle Time feature within Jira pretty much measures what is the status of an epic or bugs.
On Jira however, there's only stating collective engineer process(from PR to deploy), but there is no information for each individual PR to Deploy status on the Cycle Time feature.
I wonder if there is any method using Jira to track the speed and performance of an engineer when they received or are assigned a ticket?
You can check this article if you're looking for individual/assignee cycle time:
Hello @Gunawan Kosasih ,
This will be the same answer to your other question but still worth mentioning here.
Jira's Cycle Time report shows this metric using Jira issues, commits, and deploys. I believe, tracking this using only Jira issues makes much more sense. Your issue workflow probably already has statuses that represent all stages in the lifecycle of a task. Reporting on how much time each issue spent on each status will give much more flexible results.
If you are OK with using a marketplace app for that, our team at OBSS built Timepiece - Time in Status for Jirafor this exact need. It is available for Jira Server, Cloud, and Data Center.
Time in Status allows you to see how much time each issue spent on each status and on each assignee.
Time in Status has Consolidated Columns feature. This feature allows you to combine the duration for multiple statuses into a single column and exclude unwanted ones. It is perfect to get measurements like Issue Age, Cycle Time, Lead Time, Resolution Time etc.
For all numeric report types, you can calculate averages and sums of those durations grouped by the issue fields you select. For example total in-progress time per customer (organization) or average resolution time per week, month, issuetype, request type, etc. The ability to group by parts of dates (year, month, week, day, hour) is particularly useful here since it allows you to compare different time periods or see the trend.
The app calculates its reports using already existing Jira issue histories so when you install the app, you don't need to add anything to your issue workflows and you can get reports on your past issues as well. It supports both Company Managed and Team Managed projects.
Time in Status reports can be accessed through its own reporting page, dashboard gadgets, and issue view screen tabs. All these options can provide both calculated data tables and charts.
And the app has a REST API so you can get the reports from Jira UI or via REST.
Using Time in Status you can:
EmreT
For an alternate solution, to get this data you can try out our app.
The add-on provides the time in each status for the entire lifecycle of the issue and you can filter by issue type as well. You can also combine your statuses to define your lead/cycle/resolution time and also extract the transitions history of the issues. The main features of the app are as below
Also there is a report for the dates when issue transitioned from one status to another.
Hi @Gunawan Kosasih ,
I see that @Yuliia_Borivets__SaaSJet_ already offered several solutions for reporting and tracking performance with Jira Cycle time feature.
I might suggest yet another reporting app - the eazyBI app for Jira that allows creating simple reports and completely customized reports as well.
It allows one to see the totals and averages and also drill through assignees or projects down to each issue.
You may check the Demo account showing the dashboards created with eazyBI. The Age, Lead, and Cycle Time dashboard seem to cover your use case:
https://eazybi.com/accounts/1000/dashboards/7513-age-lead-and-cycle-time
The app is available for a 30-day free trial so you can make sure it fits your needs before making any commitments.
Kindly,
Oskars, eazyBI support
Recommended Learning For You
Level up your skills with Atlassian learning
Atlassian DevOps essentials
Learn how to build, automate, and improve DevOps processes used for the development and delivery of software and other digital products.
Tracking and improving DevOps metrics
Make informed decisions about current and future projects and deadlines to maximize your team's productivity and keep morale high.
Exploring Atlassian Cloud products for agile and DevOps
Coordinate a suite of Atlassian Cloud products for greater collaboration and trust, higher-quality solutions, faster releases, and more.
