What are the best tools for tracking objectives?
Valen Cardozo
July 14, 2021
I am training to become a Product Manager in the company where I work.
My initial task is to find a way to generate a roadmap of the different objectives that arise per quarter and follow up on them.
The possibility of acquiring Jira Premium is discarded since only 2 members would make use of the functionality and the cost / benefit is not convenient.
What other Atlassian integration apps do you recommend to carry out this task?
Fabian Lim
August 4, 2021
Hi @Valen Cardozo
I would recommend big picture enterprise. It contains a roadmap and objectives module, but it's pricey if only 2 people are using it.
At no cost, you should be able to create an objectives issue type with it's own workflow and have a custom field that tracks which quater it belongs to. Then use a kanban board to track its progress. You can also link it to epics to ensure what the scope of the objectives are.  This is what we did when we started with jira and had no budget to acquire apps.
Regards
Adam _SoftwarePlant_
Hi @Valen Cardozo
To add up to whats @Fabian Lim already mentioned - you may want to consider purchasing just a standard version of our BigPicture product since it already contains multiple modules - Roadmap included, in order to allow you to manage your projects as well as resources. BigPicture Enterprise extends the standard feature of BigPicture so you can consider this step at a later stage.
I hope this helps,
Best regards,
Adam
Like Anna-BigPicture likes this
