Difference between Jira Work Management and Trello?
Daniella_Johnson
My team is trying to decide between Jira Work Management and Trello to manage tasks and help requests but are struggling to find big differences between these two products. What are the main differences if any?
11 comments
Deleted user August 26, 2021
@Daniella_Johnson the same difference you have between a Harley Davidson motorbike and a Ferrari F-40... both are vehicles for transporting people. I'd let my friend  @Vero Rivas , who is an expert, answer that question. Then you'll have to see what you want to do exactly. Did you choose Trello because it's free in its initial version? Have you already tried JWM?
Like • Vero Rivas likes this
Daniella_Johnson
We have not used Trello or Jira Work Management yet. Some teams at our company have used Jira Service Management, but we don't need as much of the ticketing capabilities. We are looking to manage our projects and the tasks within them, but have something like a form from slack or confluence plug into JWM or Trello as one of those tasks.
Like • Deleted user likes this
Brendan O Reilly
I am also interested in this topic.
Trello seems much lighter weight and better suited to visualisation of unstructured or once off work.  The order in which tasks is completed for instance may be less relevant. Email is very heavily involved in communication.
JWM is more suited to actual work flows where the ownership and tasks need to be completed in a specific sequence and where that is a recurring piece of work - less email etc.
Like • 3 people like this
Daniella_Johnson
This was helpful thank you! Because what we are looking for, having a designated email and then those plugging into Trello would work well for us.
@Daniella_Johnson
I agree with what  @Brendan O Reilly  told you. If you are looking for a streamlined tool, then use Trello. I didn't understand if you have tried Jira Service Management or if you are using it and would like to integrate it with Trello. If you want to try JWM instead, activate a cloud instance, it's free up to a certain number of users and you can get an idea.
Like • bit2bit Americas likes this
Daniella_Johnson
I have not tried Jira Service Management yet- not trying to integrate that with Trello.
Vero Rivas
August 28, 2021
Hi @Daniella_Johnson
  Thanks for the detail @[deleted]
  I always say that first you have to be clear about what type of work you want to do so that you can then analyze the potential of the tools and see which one suits your needs, then obviously it is necessary to assess:
    + Costs
    + Accessibility (mobile application), if necessary
    + Number of users, etc.
 Anyway if you need help together we will try to give you a hand and give you our humble opinion
Cheers
Mike Rathwell
August 26, 2021
The other bit I would add to this... While JWM isn't as pretty as Trello, it is almost feature parity, allowing users to have the fully ad-hoc operation some of them desire. HOWEVER, if you are using JSW elsewhere, using JWM and team managed projects gets rid of a source of truth. I see many cases where I am still combatting this with users maintaining spreadsheets to rationalize JSW and <insert tool here> and/or adding custom fields in one or the other to manage said linkage.
If you go the JWM route, you can actually link the issues between JWM and JSW directly which gets rid of one rather manual and error prone step. Even better, when a user group on <insert tool here> outgrows it or decides that real process and control is a Good Thing, it may take little or even no effort to MOVE those issues into a JSW project including all their history and other goodness.
Like • 10 people like this
Tayla King June 7, 2024
Hi @Mike Rathwell have you found a way to easily duplicate recurring project management work flows in JWM.
For example, if I want to duplicate an entire project (that we know will be recurring many times throughout the year) with tasks and dependencies, is it possible?
I have not found an easy way to do this as of yet
Howard Eberhart
August 26, 2021 edited
The kind of team you are a part of should also be taken into consideration.  Trello may fit a smaller team with a low volume of requests per week/month and are more visually oriented. Many business teams like Trello better because it fits into their style of working.
Like • 5 people like this
Kevin Tuei
To put the comments into context, it seems that your choice of the tool to adopt is around the people who will use them rather than choosing the tool then expecting people will get the hang of it.
Marjorie
October 27, 2021
Thanks for the information on the differences.  Helps me!
Gaurav
Thanks @Daniella_Johnson  for the great questions and others for sharing the insights about Trello and JWM.
Pramodh M
Have you been able to decide which tool to go with?
Let us know on what factors you chose the tool
Daniella_Johnson
Hi! My team decided to go with Jira Work Management because of the automations, components and more flexibility in the workflows and statuses, to be able to better sort and manage smaller projects within the overarching Project. It has worked great for our team, and we're in the process of getting all the teams in our company into JWM too!
Like • 2 people like this
Dave Mathijs
Good choice @Daniella_Johnson
Darryl Lee
March 16, 2022
To my knowledge, Jira Work Management is the business project of Jira Software Cloud.
It offers the streamlines template and retains the functionalities as Jira Software Cloud mainly for the business teams to manage their projects.
Trello, on the other hand, is a very flexible and powerful product to fit in many usage scenarios.
There are some similar features across these 2 products, but from my perspective, the main point to be concerned is the cross-product workflow while Jira Work Management is native with other Jira Software projects and Trello needs Add-ons to achieve.
Just my opinions. :)
Like • Yuly Buenahora likes this
Summer Hogan
I know this discussion is old, but I found it very useful! I find Trello to have so many uses and it is one of Atlassian's most flexible products. I even use it for my persona TO DO and WANT TO DO lists! It also makes for a great BUCKET LIST tool!
Sam Yeung
August 28, 2022
We are also researching should we use Trello or Jira Work Management for our business team.
One KEY difference is DESKTOP App and Mobile App. Trello do offer desktop app but Jira Work Management not. This could be one of the key factor considering the productivity increase by having desktop app.
Has anyone found a way to easily duplicate recurring projects in JWM as you can in Asana (without being an admin)
