How to preform stress testing on JIRA
Basha November 27, 2018
Can you please help me with, How to preform stress testing on JIRA , Step by Step.
Thanks in Advance!!!
BR
A.Khan
1 comment
ddomingo
November 27, 2018
Hi Ameer! I'm not sure yet what you're testing for, but you might find this useful -- head over to:
https://confluence.atlassian.com/enterprise/scaling-jira-7-12-955176050.html#ScalingJira7.12-methodologyTestingmethodology
This testing methodology explains how we at Atlassian benchmark the performance of each Jira release. That section lays out the environment/infrastructure, dataset, and user actions we used.
Once you set up your instance and load it with your dataset, you can use JPT (Jira Performance Tests) to run the different user actions listed in that methodology:
https://bitbucket.org/atlassian/jira-performance-tests/src/master/
I must add that JPT is currently in beta, and is still therefore unsupported.
Just to add: we benchmark each release of Jira, and compare it with previous releases. We publish each version's benchmarks here:
https://confluence.atlassian.com/enterprise/scaling-jira-867028644.html
Hope that helps!
Like # people like this
