Is it possible to selectively enable smart commit hashtags in FishEye? For example, I would like to completely disallow transition smart tags while allowing the comment hashtag.
Hi Thierry,
It is possible to disable smart commit JIRA integration leaving Crucible smart commit features enabled, but it is not possible to selectively disable parts of JIRA integration.
If you wish to disable JIRA smart commits entirely, you can do so from the Smart commits page in the administration.
Kind Regards,
Richard Stephens
