I'm locking for the line in the css file to change the color of the marked line of code in crucible. The standard-color is not good to see on some beamers.
Kind Regards,
Tim
Hi Tim,
if you want to edit Crucible's CSS, changing this should do the trick
.inlineSource .lineHighlighted, .inlineSource .lineHighlighted .diffLineNumbers, .inlineSource .lineHighlighted .diffLineNumbersA, .inlineSource .lineHighlighted .diffLineNumbersB, .inlineSource .lineHighlighted .diffMarkerCol, .inlineSource .lineHighlighted .diffContent, .inlineSource .lineHighlighted .diffContentA, .inlineSource .lineHighlighted .diffContentB, .inlineSource .lineHighlighted .ediffContentA, .inlineSource .lineHighlighted .ediffContentB/*, .inlineSource .lineHighlighted .ediffChangedA, .inlineSource .lineHighlighted .ediffChangedB*/ { background-color: #ebf2f9; }
Alternatively consider using a browser extensions that allows you to inject your own CSS styles into pages (like Stylebot or Stylish for Chrome). That way you don't need to modify your Crucible installation, and you can change the styles without affecting other users.
Something like this worked for me in Stylebot:
.lineHighlighted td { background-color: #f2baf2; }
