In the FishEye SSL configuration page, it explains how to configure FishEye for SSL. It suggests creating a certificate and adding it to a Java Keystore and pointing FishEye at it. But what if your Java keystore has multiple certificates stored within it? Does FishEye choose the first one? If all your certificates have aliases, can you tell FishEye which one to use (like Tomcat)?
Hi
1. The system (Fisheye) will try to find a certificate which the related private key is present. So Fisheye will be able to bind the TCP port and wait for SSL requests.
2. If the related keystore has multiple certificate with valid private keys (for each one), it will try to use the certificate which has the CN value equal to the hostname
In Tomcat, you can add the tag keyAlias
(case sensitive) on trying to specify the alias that the app. server should use. However, since Fisheye use Jetty, I don't believe that it could works.
However, if would like to try, open config.xml for editing and add the tag
keyalias (not sensitive) with the other ones. For further details, please review the following link:
Cheers
Paulo Renato
Got SSL working on Nexus which also uses Jetty...seems Jetty will default to an alias called... "jetty". Quite obvious when you know the answer... but so frustrating beforehand.
