I'm attempting to configure a repository using SVN Symbolic Rules because my repository uses uppercase Trunk, Branches, and Tags instead of the expected lowercase. But I'm having trouble getting the Regular Expression correct.
The repository takes the form:
As an example, for the Trunk, I tried the regular expression:
Regular Expression: ([Tt]runk){1}(.[^\/]+)
Logical Path Prefix: ${2}When I run the URL using the Test Path:
https://svn.myrepository.com/svn/ABC/MyProject/Trunk/Some.config
It comes back with "No Logical Path"
I also tried using some of the examples I've seen in Atlassian's documentation, but they also don't seem to work.
Regular Expression: Trunk/([^/]+)
Logical Path Prefix: <blank>
Hello!
It looks like these are not among the default presets, so please make sure that you have "Use Built-in Symbolic Rules" unticked, and the "And then Apply the Following Rules" set to "Custom".
Also, please note that you can have more than one rule for the trunk / branches / tags structure by clicking the "Add" link next to them, so you can use more than one Regular Expression for each.
For example:
Here you can see that I have a file at "/trunk/file.txt".
Now, have a look at the SVN Symbolic Rules:
As can be seen here, I have defined more than one Regular Expression for Trunk, for Branches and for Tags, in order to make things easier.
When I typed the path "trunk/file.txt" and hit the "Test path" button, it was recognized as valid. If I modify the path to "Trunk/file.txt", it is also recognized as valid.
I hope this helps!
