×Hi,
I am very new to Java but have developed in other languages. I am trying to create a simple event listener that triggers a script upon a ReviewCompletionEvent. Went through as much of the docs as I can but I just need some help to get started. These are some of the KB I referenced:
Questions
private static final Class[] HANDLED_EVENTS = new Class[] { ReviewCompletionEvent.class }; public Class[] getHandledEventClasses() { return HANDLED_EVENTS; } public void handleEvent(Event event) { if (event instanceof ReviewCompletionEvent) { /* INSERT Instructions to perform once the ReviewCompletionEvent is found */ } }
<listener key="example-listener" class="com.yourcompany.fecru.listener.ReviewCompletionEvent"/>
Type atlas-run in the root of your project and see whether it worked
Hopefully that will get you on your way.
Oops! Crucible/FE. I assumed ReviewCompletionEvent would only be a FE/Crucible method.
After a code review is completed I would like to have a listener trigger a script. With this ability the script can give me great power and flexibility with my SDLC workflow. I would like to pass to this script a param or two as well.
Which app are you talking about?
