I'm not sure if this is a recent change since I believe this was working before. I want to delete a Crucible review in draft mode via REST API. I was able to delete a draft with the REST endpoint
/rest-service/reviews-v1/{id}/transition?action=action:deleteReview
However, the response i get now when trying to transition a review in draft to delete is
"{"code":"Authorization","message":"You can't do action:deleteReview in state Draft"}"
If I transition the review to abandon first then attempt to delete, the error I get is
{"code":"Authorization","message":"You can't do action:deleteReview in state Dead"}
Hi, Did you every figure this out. I have the same scenario
<?xml version="1.0" encoding="UTF-8" standalone="yes"?><error><code>Authorization</code><message>You can't do action:deleteReview in state Dead</message></error>
