Detect language for syntax highlighting based on shebang in Fisheye
Matthias February 23, 2016
We have executable Python scripts in our repository that do not include a *.py file extension in their name. Therefore, the syntax highlighter of Crucible/Fisheye is not able to detect the language. But we have a shebang included in the Python script. So, there is some information about the programming language in the file which could be used by the syntax highlighter for language detection.
I found something for Stash: https://confluence.atlassian.com/display/STASHKB/Configuring+syntax+highlighting+for+file+extensions
Is there something similar for Fisheye/Crucible syntax highlighting?
*edit*
To be clear: I am NOT interested in defining syntax highlighting. I want to detect the language of a file (using the shebang in the header of the script) to determine which existing syntax highlighting to use. The Python script does not have a *.py file extension that could be used for detecting the language but a shebang in first line of the executable Python script like that:
#!/usr/bin/python
# any python code follows
Tini Good
February 24, 2016
Matthias February 24, 2016
Thanks for the suggestion. But I am looking for something to derive the language of a file from the shebang in its header and not from its file extension. I couldn't find a description of this feature in your wiki articles.
Marek Parfianowicz
February 23, 2016
Hi Mattias, file extension mappings for syntax highlighter are defined in <fisheye dir>/syntax/filename.map
Murty Chitti February 28, 2016
Hi Marek,
we had the synatx/filename.map entry for the files with extenstion .py and it is working for files having correct extension.
"**/*.py" python.def "Python"
is there any option for files not having extenstion to be identified like  MIME type ?
we had tried  the below in raw-mime.types
application/python py
application/x-python py
text/x-python python py
text/python py
and also
text/plain asc ascx asmx asa asax ashx axd config txt java jsp asp aspx cs idl cpp cxx c h pl pod py sh awk sed sql jspf tag xaml frm vb browser master
csproj vbproj sitemap
but syntax highlighting not working for files without .py extenstion .
any options to enable syntax highlighting for files which do not have extension in fisheye?
