Fisheye Scanning subversion repository Issues
Karanam Subbarao
We created a repository inside a Fisheye/Crucible and started scanning. While it was scanning, the system was restarted for weekend reboot. After the weekend reboot it stopped scanning and it is throwing following Exception. How do I rescan teh repo again..
com.cenqua.fisheye.rep.DbException: java.io.FileNotFoundException: /local/data/appdata/software/infra/apg/internal/Crucible_DATADIR/cache/globalfe/idx1/_13kq.cfs (No such file or directory)
at com.cenqua.fisheye.lucene.LuceneConnection.withWriter(LuceneConnection.java:577)
at com.atlassian.fisheye.quicknav.QuickNavIndexer.deleteRepFromIndex(QuickNavIndexer.java:80)
at com.cenqua.fisheye.rep.BaseRepositoryScanner.doCrossRepoRescanCheck(BaseRepositoryScanner.java:399)
at com.cenqua.fisheye.rep.BaseRepositoryScanner.slurpRepository(BaseRepositoryScanner.java:253)
at com.cenqua.fisheye.rep.BaseRepositoryScanner.doSlurpTransaction(BaseRepositoryScanner.java:225)
at com.cenqua.fisheye.rep.BaseRepositoryScanner.ping(BaseRepositoryScanner.java:184)
at com.cenqua.fisheye.rep.BaseRepositoryEngine.doSlurp(BaseRepositoryEngine.java:92)
at com.cenqua.fisheye.rep.RepositoryEngine.slurp(RepositoryEngine.java:383)
at com.cenqua.fisheye.rep.ping.OneOffPingRequest.doRequest(OneOffPingRequest.java:28)
at com.cenqua.fisheye.rep.ping.PingRequest.process(PingRequest.java:67)
at com.cenqua.fisheye.rep.RepositoryHandle.processPingRequests(RepositoryHandle.java:138)
at com.cenqua.fisheye.rep.RepositoryHandle.queuePingRequest(RepositoryHandle.java:128)
at com.cenqua.fisheye.rep.ping.PingRequest.run(PingRequest.java:33)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
Caused by: java.io.FileNotFoundException: /local/data/appdata/software/infra/apg/internal/Crucible_DATADIR/cache/globalfe/idx1/_13kq.cfs (No such file or directory)
at java.io.RandomAccessFile.open(Native Method)
at java.io.RandomAccessFile.<init>(RandomAccessFile.java:216)
at org.apache.lucene.store.SimpleFSDirectory$SimpleFSIndexInput$Descriptor.<init>(SimpleFSDirectory.java:76)
at org.apache.lucene.store.SimpleFSDirectory$SimpleFSIndexInput.<init>(SimpleFSDirectory.java:97)
at org.apache.lucene.store.NIOFSDirectory$NIOFSIndexInput.<init>(NIOFSDirectory.java:98)
at org.apache.lucene.store.NIOFSDirectory.openInput(NIOFSDirectory.java:78)
at org.apache.lucene.index.CompoundFileReader.<init>(CompoundFileReader.java:67)
at org.apache.lucene.index.SegmentReader$CoreReaders.<init>(SegmentReader.java:115)
at org.apache.lucene.index.SegmentReader.get(SegmentReader.java:605)
at org.apache.lucene.index.IndexWriter$ReaderPool.get(IndexWriter.java:622)
at org.apache.lucene.index.IndexWriter$ReaderPool.get(IndexWriter.java:597)
at org.apache.lucene.index.DocumentsWriter.applyDeletes(DocumentsWriter.java:1002)
at org.apache.lucene.index.IndexWriter.applyDeletes(IndexWriter.java:4566)
at org.apache.lucene.index.IndexWriter.doFlushInternal(IndexWriter.java:3756)
at org.apache.lucene.index.IndexWriter.doFlush(IndexWriter.java:3595)
at org.apache.lucene.index.IndexWriter.flush(IndexWriter.java:3585)
at org.apache.lucene.index.IndexWriter.prepareCommit(IndexWriter.java:3459)
at org.apache.lucene.index.IndexWriter.commit(IndexWriter.java:3534)
at org.apache.lucene.index.IndexWriter.commit(IndexWriter.java:3505)
at com.cenqua.fisheye.lucene.LuceneConnection$IndexHandle.commit(LuceneConnection.java:146)
at com.cenqua.fisheye.lucene.LuceneConnection$IndexHandle.access$600(LuceneConnection.java:76)
SomnathK April 2, 2013
This solution worked for me:
Delete the following folders and restart FishEye/Crucible
<FISHEYE_INST>/cache/globalfe
<FISHEYE_INST>/var/cache/<REPO_NAME>
Fisheye was able to re-create the cache files and re-scan the Repo.
Hi Lucas,
Tried following the Re-indexing steps, but it does not work.
Somnath
Conor
April 2, 2013
Could you elaborate on what "does not work" means?
LucasA
April 1, 2013
Hi Karanam,
The FishEye index is corrupted -- actually an index file has been removed on the reboot (/local/data/appdata/software/infra/apg/internal/Crucible_DATADIR/cache/globalfe/idx1/_13kq.cfs). Please proceed according described here:
- https://confluence.atlassian.com/display/FISHEYE/Re-indexing+your+repository
Best regards,
Lucas Timm
