×I am a newbie to python and am trying to create a script to login to crucible and use the token to pass to other services.
1) I am able to make a xml request and get a response but as soon as I pass the headers to my conn.request it says HTTP Error 415, unsupported Media Type.
I have done quiet a bit of research on this topic and found out that the rest API might not be supporting the json reques, but Crucible says that there API supports json so seems to be some other issue,
2) when trying to pass the args generated using feauth the auth token is not getting used , for now I have appended it to url and it works.
Please help me with the same , below is my script
import httplib
import urllib
import json
from xml.etree.ElementTree import XML
import xml.dom.minidom
conn = httplib.HTTPSConnection("fisheye")
args=urllib.urlencode({'userName':'UNAME', 'password':'PWD'})
headers={'content-type':'application/json', 'accept':'application/json'}
#headers={'Authorization' : 'Basic %s' % base64.b64encode("username:password")}
r1 = conn.request("post", "/rest-service/auth-v1/login", args)
#status = r1[u'headers']['status']
#conn.connect()
r2 = conn.getresponse()
print r1,r2.status,r2.reason,r2
r3=r2.read()
print(r3)
r4=str(r3)
print r4
data = XML(r4).find("token").text
print data
# data1=urllib.quote_plus(data, safe=":")
# print data1
args=urllib.urlencode({'FEAUTH':data}).replace("%3A", ":")
print "args is", args
#args={}
req = conn.request("get","/rest-service/reviews-v1")
r3 = conn.getresponse()
status = r3.status
print "the url is"#, r3.getheader('Location')
url=r3.getheader('location', '')
print url
url1=r3.msg#.dict['location']
print url1
#print req.url
#print req.get_method()
print dir(req) # list lots of other stuff in Request
print "after sending open review request"
print r3
print req,r3.status,r3.reason,r3
r4=r3.read()
print(r4)
r5=str(r4)
print r5
# json_ob=json.loads(r3.read())
# print json_ob
Thanks for replying, I had already checked the above mentioned URL and was trying in same way but was still getting exception.
I was able to resolve the issues and here are answers for someone facing similar issues
1) changed the line headers={'Accept':'application/json'}
that is removed the content-type and sentence cased Accept
2)I was not able to pass the arguments to login request because it was a get request and so we need to append the values to URL and not try to pass it as argument.
Hi Amit,
Have you checked this page?
- https://developer.atlassian.com/display/FECRUDEV/Writing+a+REST+Client+in+Python
It has a good example to performing REST calls on FishEye/Crucible. It may be used with JIRA as well -- you'll only need to change the request's URL.
I hope it helps!
Best regards,
Lucas Timm
Hi Lucas,
reviews = toList(json.loads(resp[u
'body'
])[u
'reviews'
],u
'reviewData'
line is giving error when executing example given on Lucas's link:
Traceback (most recent call last): File "C:\crucible\fecru-3.2.4\content\api\rest_client_reivews.py", line 44, in <module> reviews = toList(json.loads(resp[u'body'])[u'reviews'],u'reviewData') KeyError: u'reviews'
Any suggestion?
Based on Amit's code:
import httplib import urllib import json conn = httplib.HTTPConnection("codereview.site.optiver.com") args=urllib.urlencode({'userName':'myuser', 'password':'*****'}) headers={'accept':'application/json'} conn.request("post", "/rest-service/auth-v1/login", args, headers) r = conn.getresponse() if r.status not in (200, 304): raise Exception("Problems getting a token from codereview. %s %s" % (r.status, r)) token = json.loads(r.read())["token"] token=urllib.urlencode({'FEAUTH':token}).replace("%3A", ":") req = conn.request("get","/rest-service-fecru/admin/repositories-v1/business_intelligence?%s" % token, None, headers) r3 = conn.getresponse() status = r3.status json_ob=json.loads(r3.read()) print json_ob
After resolving the above mentioned problems I am now stuck at the next step , that is passing the auth token and json argument both to the rest API to create a review.
I am trying
data = json.dumps({ "reviewData" : { "projectKey" : "EEU", "name" : "Example review.", "description" : "Test Description", "author" : { "userName" : "user", "displayName" : "User User", "avatarUrl" : "https://fisheye/avatar/user?s=48" }, "moderator" : { "userName" : "user", "displayName" : "user user", "avatarUrl" : "https://fisheye/avatar/user?s=48" }, "creator" : { "userName" : "user", "displayName" : "user user", "avatarUrl" : "https://fisheye/avatar/user?s=48" }, "permaId" : { "id" : "EEU-598" }, "permaIdHistory" : [ "EEU-597" ], "type" : "REVIEW", "allowReviewersToJoin" : "false", "metricsVersion" : "2", "createDate" : "2013-03-11T15:38:54.046+1100", "dueDate" : "2013-03-12T15:38:54.046+1100", "jiraIssueKey" : "" } }) data1 = (data) args=urllib.urlencode({'FEAUTH':token}).replace("%3A", ":") req = conn.request("post","/rest-service/reviews-v1"+"?"+ args, data1, headers)
The above code snippet is the only change that has happened in the code provided in te question
Adding the content type resolved the issue .
Content-Type: application/json
