×Hello,
I'm trying to make some interface modification in fisheye 2.8 but have difficulty because, i'm thinking, you're using cache system.
I need to modify the header banner (including logo) and the favicon.
Thanks for help.
Hi KeavenMartin,
Take a look at this article about customizing FishEye/Crucible logo. That could be helpful.
Leonardo.
Hello Macedo,
Thanks for help, but when i modify fecru.png to change logo and I restart the logo doesn't change. I have verify the web page and the image was in the correct file and i view all image in this page via browser http://192.168.1.234:8003/fisheye/static/m8qhao/2static/images/masthead/ (localy), but if I look at the fecru.png image it was the default one and not mine.
Do you have others ideas.
That's weird! I've tested locally and logo has changed. My steps were:
1. In my case I have FishEye+Crucible so I've stopped application.
2. gone to /fisheye/static/m8qhao/2static/images/masthead/
4. replaced original fecru.png for a customized logo keeping the name fecru.png (of course) which is referenced into code.
5. Started application.
Application will start with old logo but when I hit F5 the new logo is loaded and displayed.
Could you please review your steps and make sure you've followed these steps?
Leonardo.
I have found the problem, I only have to clean the navigator cache after.
Now I'm trying to modify the favicon .../fisheye/static/m8qhao/images/favicon.ico but this doesn't work. I have clear my browser cas and restart fisheye/crucible.
Do you have one idea?
Hey KeavenMartin,
Well the favicon file that you're trying to change is correct. I was able to modify it and my steps were:
1. downloaded a program to convert images to .ico files (I used SimplyIcon);
2. turned a image into .ico file, renamed it to favicon and replaced it into m8qhao/images/ folder;
NOTE: for some reason the SO (windows in my case) keeps displaying the old favicon image even after replacement (well I just ignored that...);
3. Then I've started application and cleaned browser cache (FF in my case)
4. So new favicon has been displayed.
I hope this could help you.
Leonardo.
