We are deploying Bitbucket server and Fisheye/Crucible servers. I was able to connect the bitbucket repos to crucible/fisheye but now I can not get them started. I get the above error, can anyone help?
Thank you in advance!
Hi Enrique,
Welcome to the Atlassian Community.
Make sure you have installed Git on your Fisheye/Crucible server and part of your path variable, it does not come bundled with the install.
We have in in our Bitbucket server, I am connecting the repos from there, the repos are in fisheye now but I get that error when I try and start them.
I don't think I have to have git on both servers do I?
Yes, it needs to be installed on the Fisheye server too. It is using it to read from the remote repository.
