Sign up Log in
How to use accurev as version control system with crucible
MOHIT SAXENA November 25, 2014
In our project we are using AccuRev as version control system. What are the options available for us to use crucible as a code review tool.
If we install Fisheye with crucible, would it work or can we go for the accurev plug-in ?
Would be please to get reply from you guys.
Thanks in advance. smile
rstephens
November 25, 2014
FishEye/Crucible does not have any built-in support for AccuRev.  AccuRev publishes an official plugin on the Atlasssian marketplace:
https://marketplace.atlassian.com/plugins/com.atlassian.crucible.accurev.scm.accurev-scm-plugin
Kind Regards,
Richard Stephens
Hi Richard, Thanks a ton for your quick response. So, does it implies that i can install crucible without installing FishEye but i need to use the plug-in for accurev ? Regards Mohit Saxena
Felipe Kraemer
November 26, 2014
Hi Mohit, You're right. You can use Crucible without FishEye: https://confluence.atlassian.com/display/CRUCIBLE/Crucible+and+FishEye And you need to use the AccuRev plugin that Richard mentioned before. Kind regards, Felipe Kraemer
MOHIT SAXENA November 30, 2014
Thanks Felipe :)
