×Hi,
I have performance issue on Crucible/Fisheye. Is it safe to use mod_cache for this one?
-Hieu
I wouldn't say you're going to get a silver bullet when it comes to performance with FishEye/Crucible. You probably want to speak speak to support and they can help tune your instance. Often misconfigured instances cause performance issues, but it really depends on how you are using the product, how big your repositories etc.
