×Hi,
I already figured out how to create JIRA Issues from Crucible Comments/Defects. But there is only an option to set the corresponding Project an description to the issue. When I look it up after creation, the task is neither assigned to a person (which would likely be the author) nor to a Lable or Component.
So I have to to that in another step, wich is a inconvinience. Is there a way to assign the issues manually or automatically during the creation in Crucible?
To my knowledge, not from Crucible. However, you can configure JIRA to assign a default Assignee for all new Issues by setting "Allow unassigned issues" to OFF in your project configuration. See: https://confluence.atlassian.com/display/JIRA/Configuring+JIRA+Options
That should apply even if they are created from Crucible. Unfortunately, since JIRAs created from Crucible don't allow you to designate the Component either, your default Assignee will always by Project Lead, so you may still have a reassignment step.
