If I use SVN repositories for code review projects, with some repositories only the first commit entry is shown. I suppose that it can have to do with the property change of the repository, because I only have this problem with repositories where the property change is one of the commits of this repository. If I set the start revision to a later revision (after property change), it also shows only this start revision in the review project, all others are missing.
Could you please suggest what the problem could be?
