We are using Jira with Fisheye+Crubible, after some resetting of project repositories, we noticed that crucible control now appeared but this was not happening before (please see attachment), how do we disable it? Thanks.
I was able to remove crucible control by configuring:
Administration > FishEye Configurattion > 'Edit' FishEye server > set Enable Crucible Integration to 'No'
On mine, it just says "Create crucible review for all X changesets". If I click to create, it brings up the Crucible create review screen with the correct project already selected (although I can change it via drop-down). I'm wondering you haven't linked the projects between JIRA and Crucible? One you link the systems, you link each project. In JIRA Administration for your project, under Application links, do you see links to both a Crucible Project and a Fisheye Repository?
