Upgrading Crucible/Fisheye Problems
Chad DeShaw
December 5, 2017 edited
I want to upgrade Crucible and Fisheye, do I need to upgrade them separately?
Does it matter which one I upgrade first?
I used the crucible installer and it wiped out repositories that were there, I had to reconnect it to jira and now I am getting exceeded users message for license. Every upgrade I have had to do with Atlassian products is a pain.
Also it is not using the postgresql db anymore, so it must have wiped out those settings too.
I had this running as windows service,, I also used Jira as a user store,
So I guess I need help figuring out what went wrong and how to get it back to what it
Is there a way to get more advanced help with this problem?
Chad DeShaw
December 8, 2017 edited
I had to recreate the ENV variable on Windows, not sure how it disappeared and  uninstall and reinstall the 4.5.1 version 2 more times and delete the data directory that got created on C: somehow and it finally worked. I also had to copy the postgresql-42.0.0.jar to C:\Atlassian\fecru-4.5.1\lib
Chad DeShaw
I have a starter license, how do I get help now?
I already went thru those docs.
I checked the config.xml file in the FISHEYE_INST dir and it still has the repository info there for repositories I added, and the connection string to postgresql.
I am not sure why it is using postgresql and it is instead running the local built in hsqldb, also it is not using Jira as the user store, so the only way to log in right now is as admin.
Is there anyway to purchase support incidents, so I can get some help?
Grzegorz Lewandowski
December 6, 2017
Fisheye/Crucible is an single application with dual licensing (Fisheye and Crucible). You can freely upgrade the application and both products will be upgraded.
Chad DeShaw
December 6, 2017 edited
Ok I am confused , which installer do I use to perform the upgrade?
Chad DeShaw
Chad DeShaw
I checked the config.xml file in the FISHEYE_INST dir and it still has the repo info there and the connection string. I am not sure why it is not being used and it is running the built in hsqldb.
December 7, 2017
Here are the guides how Fisheye/Crucible application should be upgraded:
https://confluence.atlassian.com/fishkb/migrating-and-upgrading-fisheye-crucible-423298099.html
https://confluence.atlassian.com/fisheye/upgrading-fisheye-on-windows-600115292.html
https://confluence.atlassian.com/fisheye/fisheye-upgrade-guide-298976988.html
https://confluence.atlassian.com/crucible/crucible-upgrade-guide-298977392.html
It's hard to guess what's wrong. I recommend raising an support on https://getsupport.atlassian.com/  where Support Team will be able to gather more information and provide help.
Chad DeShaw
Chad DeShaw
Is there anyone that can help me?
Do I need to create a new ticket to get help?
Chad DeShaw
Tell me do you have to reconfigure the db connection string in the UI when you update?
Chad DeShaw
Ok I see one thing that is wrong, somehow the FISHEYE_INST Environment variable is now wrong after the upgrade FISHEYE_INST C:\Atlassian\fecru-4.5.1\bin\..
Instead of F:\Atlassian\Data\fecru
atlassian, confluence administration certification, atlassian certified professional, confluence admin for cloud, atlassian learning, confluence training, confluence certification exam, confluence cloud admin, admin credential, atlassian certification
Become a certified Confluence admin today! 📖
Stand out as a skilled Confluence Cloud administrator. The Confluence Administration for Cloud certification proves you can configure permissions, manage site and space settings, and monitor activity—ensuring secure, effective collaboration for your team.
