Why do no rooms appear when configuring Go2Group HipChat Fisheye integration?
Scott Strmel
Installed the Go2Group HipChat Fisheye integration, created a HipChat API Token, added it to the plugin configuration, and configured the Basic Access Authentication between Fisheye and JIRA. When trying to add a room to a Fisheye project or repository no rooms appear in the selection form.
Plugin 1.3.3
JIRA 7.0.5
HipChat 1.0
Murali August 21, 2016
Scott,
Can you please check if the user configuring in Fisheye owns any room in Hipchat?  User between the Fisheye & HipChat are mapped based on the users email address.
Scott Strmel
Yes the user owns at least one private room.
Murali August 25, 2016
Does the email id match between the Fisheye and HipChat accounts for the User?
