Why is FishEye is not starting?
Damian Nelson
August 24, 2011
I can't get FishEye to start.
I have:
-Downloaded FishEye zip file
-Unzipped file
-go into bin folder and run ./run.sh
Then I get Killed message.
I am trying to run this on Linux server.
I don't know what to do.
Conor
August 25, 2011
Are you running the default Java install on Linux? We recommend using an Oracle JVM to run FishEye.
There is more information here:
http://confluence.atlassian.com/display/FISHEYE/Supported+Platforms
Radu Dumitriu
August 25, 2011
Please make sure you are not using OpenJDK. Do a `which java`
MatthewC
August 25, 2011
Can you include some more info?
What's in the logs?
I presume that you've verified Java is running OK & the correct version?
