how to undo deleted comment in Crucible ?
Ahmed Khaled September 30, 2015
I find it very annoying to have the edit & delete buttons very close to each other. As I some time delete comment in crucible accidently. Is there any way to undo deleted comments in Crucible or at least show confirmation dialog before deleting a comment ?
lpater
October 1, 2015
Hi Ahmed,
You can click 'Tools' and then 'View Review History' to see all the comments made on the review in the chronological order, including the deleted ones. You should be able to recreate the comment based on that.
There is a feature request to add a confirmation dialog for the deletion at https://jira.atlassian.com/browse/CRUC-1627 - please vote for it if you'd like to see that implemented.
Best regards,
Lukasz Pater
_Nebula_
March 4, 2019
That ticket has been stale for almost 10 years now... By the way, 'undo' is not the same as a confirmation dialog. Undo would actually be better :-)
Ahmed Khaled October 1, 2015
I couldn't find how to recreate/restire the deleted comment from the review history
@Lukasz Pater
lpater
November 11, 2015
You'll need to manually copy the comment text, and recreate the comment.
