Hi Carlitos,
I believe the first step in order to troubleshoot this issue is to investigate the application versions:
Have the smart commits stopped working completely, or some of the functionalities still work? Remember you can use smart commits to transition JIRA issues, comment on JIRA issues, log work on JIRA issues, etc...
Can you please check if Smart Commits are still enabled and if you're still using the correct syntax? Can you provide us with a sample Smart Commit you're using?
Does it work for some users, or it doesn't work for anyone at all?
Apparently it's some permission issue between Jira and Fisheye. Not sure why it stopped working. It was definitely working before. I'm using Jira as a User Server. Atlassian support is looking at it. Any ideas are welcome.
