When creating a custom automation, how do I distinguish between someone entering a comment on the "internal" or "Customer" tabs as the triggering event?
Community moderators have prevented the ability to post new answers.
Hello @Brian Oconnell
Are you using the standard automation or automation for jira? It is possible in both. In the out of the box automation you can use "comment added" in the when-field and then choose if the comment is internal or public.
In automation for jira you can use a check to see if the comment was internal or public, one way to do it is like this:
Please let me know if this isn't what you are looking for, otherwise I hope that this answer solves your issue.
Best regards,
Alexander
Recommended Learning For You
Level up your skills with Atlassian learning
Learning Path
Get the most out of Jira Service Management
Solve customer problems efficiently and deliver outstanding service experiences.
Learning Path
Adopt ITSM practices to deliver exceptional service
Become familiar with the principles and practices that drive ITSM. Then, learn how to configure and use Jira Service Management to implement them.
Atlassian Certified Associate
Jira Service Management Agent Essentials certification
Prove you know what's essential to providing efficient and resolution-focused service in Jira Service Management.
