×The default options that come up in the Resolution field seem to be geared more toward software development than a help desk.
I'm thinking I need to add a value like "No response from user" and maybe "No issue" (for those instances when they immediately respond with "never mind, it's better now")
What do you guys think? Is there a better way to capture these scenarios? Are there other Resolution values that you've used?
Community moderators have prevented the ability to post new answers.
Hi Mary,
So, you can definitely add additional Resolutions that are more customized to your needs.
You could set those resolutions automatically depending on a specific workflow transition.
You can also restrict what resolutions appear in the resolution field by utilizing workflow properties. More info on that here.
My team uses "No Response from Customer" as a resolution that gets assigned when our custom "No Response" SLA is breached.
We also use ones like Canceled or Won't Do. They are vague but specific enough to apply to multiple scenarios.
Oh, so if it sits in "Waiting for Customer" for a certain amount of time, you can have it automatically close? That's so cool.
It's a combination of SLA configuration and Automation. You can choose a trigger for an SLA breaching.
Recommended Learning For You
Level up your skills with Atlassian learning
Learning Path
Get the most out of Jira Service Management
Solve customer problems efficiently and deliver outstanding service experiences.
Learning Path
Adopt ITSM practices to deliver exceptional service
Become familiar with the principles and practices that drive ITSM. Then, learn how to configure and use Jira Service Management to implement them.
Atlassian Certified Associate
Jira Service Management Agent Essentials certification
Prove you know what's essential to providing efficient and resolution-focused service in Jira Service Management.
