×How to connect to Enterprise Insights using Python
Tested in:
You will need:
A SQL user for Enterprise Insights
Python v3.10 (newer versions have not yet been tested. Feel free to test and update here!)
Python module pyodbc
Install the package of "pyodbc" which is ODBC Driver 17 for SQL Server as per this link:
Configure pyodbc Python environment - Python driver for SQL Server
import pyodbc
stringConnection = pyodbc.connect("Driver={ODBC Driver 17 for SQL Server};"
"Server=xxxx;"
"Database=xxxx;"
"UID=xxxxx;"
"PWD=xxxxxxx;"
"AuthenticationType=SQLPassword;"
"minimalTlsVersion=1.3;"
"Trusted-Connection=yes;")
cursor = stringConnection.cursor()
cursor.execute('SELECT * FROM current_dw.Dependency where [Dependency ID] < 20')
for i in cursor:
print(i)
Use Python to query a database - Azure SQL Database & SQL Managed Instance
Connect and query - Azure SQL Database & SQL Managed Instance
With thanks to my co-author and tester @Luiz Felipe Arruda
Heidi Hendry
Senior Cloud Support Engineer
Atlassian
Sydney, Australia
16 accepted answers
1 comment
