×This article is designed to get Jira Align Cloud to Jira Data Center connectivity up and going quickly.
Looking for the Jira Cloud guide, rather than Data Center? We've got you covered, here it is.
1) In Jira Align, click on the Administration Gear in the bottom left.
2) Click on Connectors > Jira Settings in the second column.
3) Click on the Jira Connectors button in the main pane.
4) Fill out the Jira Connector as follows:
Additional Note: If the Service Light is gray and not green, then you'll need to contact Jira Align Support to activate the service before proceeding. Please include the connector type (Jira Connector) and Connector ID (Number).
5) Once the above has been filled out, click Generate New Key and copy it to your clipboard.
6) Click Save at the bottom of the Connector window. We are done with Jira Align for the moment.
Next, we are going to sign into your Jira Software Data Center instance.
7) Login to Jira, click the Settings cog in the top right, and select Applications.
Note: Alternatively, you can click on any whitespace in Jira and press "." and search for Application Links.
8) On the left column, under Integrations, click Application Links.
9) Enter the Jira Align URL (https://__.jiraalign.com) in the field and click Create New Link.
10) Jira Server/Data Center may complain there was no response. Just click Continue.
11) Fill out the Application Name with something descriptive.
12) Click the Pencil to edit the newest application.
13) Go to Incoming Authentication and fill out the Consumer Key with the same one used in Step 4.
14) Paste the OAuth Public Key you copied from Step 5.
15) Scroll down and click Save.
16) Go back to the Jira Align Connector window from step 4.
17) Click Authorize Jira OAuth Access.
Note 1: If a Jira OAuth token authorization already exists, the button will display as Reauthorize Jira OAuth access. Clicking this will perform the same process of generating a fresh OAuth token.
Note 2: You will see this request go through 3 steps and will refresh several times. It will take a few minutes for this process to complete.
Note 3: If you are having trouble with this step, make sure that the Consumer Key matches on both sides and contains no spaces or symbols.
In addition, check that the OAuth Public Key are an exact match on both sides.
Lastly, make sure that the Application URL configured in the Jira Application Link is correct without any typos.
See OAuth Error During Setup for more troubleshooting tips.
Note: For the next step (18) make sure you are logged into Jira Server/Data Center as the Jira Service Account in another tab of the same browser. The Jira Align connection to Jira Software will use whichever account you were signed in as. If you are signed in using your personal account, that means your name will be written on any updates pushed from Jira Align to Jira Software, instead of the name of the Service Account you created.
18) Once the OAuth access setup has completed, click Request Jira for access.
19) You'll be taken to another tab asking you to allow the application to have access. Click Allow.
20) The connector screen will now show Reauthorize Jira OAuth access (instead of Authorize Jira OAuth Access, or Request for Jira Access). This is how OAuth in Jira Align will look when the process is completed:
21) Click Save on the bottom of the Connector window.
22) (Skip this step if you used OAuth as the authentication method instead of Basic Auth.) One final test to confirm connectivity is the Test Now button at the bottom of the Jira Connector window. You may need to scroll down to see it.
Note: This test doesn't automatically refresh so you'll need to close and reopen the connector window periodically. This test also takes a few minutes to complete.
23) Click Activate on the bottom of the Connector window.
24) Now that you are connected, you can sync a test project.
NOTE: For any of the authentication methods (OAuth, PAT, API Authentication/Basic Auth), if you need to change them (i.e. expired token or password), you'll need to Deactivate the connector, make the authentication update, save, and then Activate the connector.
Creating an API Service Account
James McCulley
Network & Security Solutions Architect
Atlassian
7 comments
