Jira Align does support SAML 2.0 integration and you can watch a video here on how to set it up or read below for instructions.
Video How to enable single sign on SSO with Jira Align
Azure Active Directory SAML 2.0 Setup for Jira Align
Okta SAML 2.0 Setup for Jira Align
Ping One SAML 2.0 Setup for Jira Align
This article assumes you have configured your SAML 2.0 provider with the required settings to communicate with Jira Align.
1. Sign into Jira Align and click Administration > Platform > Security.
2. Click Add SAML Provider.
3. Paste in the SAML 2.0 Metadata from your SAML 2.0 provider.
4. Click Save & Close.
5. Set Enable SSO to Yes.
6. Click Save Settings.
7. Open up an incognito window in your browser and navigate to your provider's Sign In URL. Your SAML 2.0 provider may have a different name for the Sign In URL.
It should be noted that Jira Align requires BOTH Signed Assertion and Signed Response for SAML 2.0 Providers. If you are only able to sign one of the two, then you will need to select Signed Response and open a Jira Align Support Ticket to have the assertion response requirement set to False.
See Step 2 to see the Require Signed Saml Assertion field in Jira Align.
You'll need to open a ticket with Jira Align to regain access if you get locked out while Disable Manual Sign In is turned on.
If for some reason your Sign In or Sign Out URL contain encoded characters (Example: %20 for space), you'll need to replace that with the non-encoded equivalent.
James McCulley
Network & Security Solutions Architect
Atlassian
1 comment
