×Is there a way in Jira Align to link issues between one another similar to Jira Advanced Roadmaps via the "depends on/has dependency" or "Blocks/blocked" by so that we can get that critical chain view that we'd get from Jira Advanced Roadmaps (predecsor/succesor linked with a grey thread/or red if the dates are not sequenced) ?
Many thanks team
Jira Align Dependencies are a much more powerful way to accomplish this, but if you really just want to generate data from which you could do your own critical path analysis then you could use predecessor and successor links. This is not typically turned on in Align, so you may need to ask you admin to turn it on in test so you can see it if meets your needs.
...and here is the report view
@Allan Maxwell I knew this much of the answer, but is there a good way to visualize these dependencies? To my knowledge, the only place you can see them are here in the object, or if you manually build out a dependency map
@Michael Holian I added a screenshot of the only way I know to see a visualization. Beyond that, I you would have to build something using either Enterprise Insights or data gather via API calls.
