Sign up Log in
Bulk add tags in Jira Align
Linda Redgate
Is there a way to bulk add Tags to multiple features at the same time in Jira Align?
Edvaldo Lima
June 7, 2023
Hello @Linda Redgate
Thanks for your question!
Assuming that the Features in question are integrated with Jira, I believe the easiest way can follow the steps below:
From Jira Align, I believe you can try using the Export/Import feature.
To do the export:
  1. Set the Config bar to display the data you want (like Program + PI)
  2. Go to the desired grid (Features)
  3. Click on More Options > Export <work_item> > click on the export button
  4. Add the new tags into the Tags column
  5. Save the file.
To import them:
  2. Go to the desired grid (Features/Stories)
  3. Click on More Options > Import <work_item> Select the Program > Browse (to select the file) > Import Data
I hope it helps, however, should you still encounter issues, please kindly raise a Jira Align support ticket using this link and we'll assist you accordingly.
Philipp Barry
June 8, 2023 edited
Just to highlight another possible approach: You could add the label(s) in Jira - via bulk edit - and they would synchronize to Jira Align as tags for respective integrated work.
Like • 2 people like this
Linda Redgate
I had already found this solution, and it is not really suitable for us.  I have found another way around the issue
Upcoming Jira Align Events
