Was able to export Objectives. Can export Objectives along with corresponding Key Results (work items too - product bundles, features tied to objective/key result)?
Hi @[deleted] ,
As you saw in the export file created when exporting Objectives, Key Results do not export. You can see key results progress n multiple views. I recommend these two articles:
The following columns will export to the Objectives tab of the export template:
Peter
Hi Peter - thanks for all your help! Much appreciated!
