Do sample data models or views exist for Enterprise Insights?
Elizabeth Wheeler
Hi team! Just wondering if we can skip steps in recreating the data model each time or if there is a library of existing info we can learn from.
I'm using power bi if that's relevant info. thanks!
Heidi Hendry
November 9, 2022
Hi Elizabeth,
You may also find this explainer on the Enterprise Insights schema helpful
Jira Align Enterprise Insight Data Schema - YouTube
Regards, Heidi
Rich Sparks
November 10, 2022
This video is excellent. If you understand a bit about how Jira Align works (hierarchies of work items, teams, objects, time intervals, etc.) then this video explains how to find your way through the EI schema.
Elizabeth Wheeler
I believe there are permissions around this video that are preventing me from watching it.
Rich Sparks
November 21, 2022
That link was the private, pre-release version. Here's a public link from @Sam Tsubota :
https://www.youtube.com/watch?v=qfYOS5xmE0I
And this from our colleague @Derek Huether also explains how you can use Enterprise Insights to combine with information from other systems:
https://www.youtube.com/watch?v=O5w_0SPPz5Y
Peter Jessen
November 9, 2022
Hi @Elizabeth Wheeler , If you go to Align’s help and login you can find the latest EI schema under the Enterprise Insights help. You won't see the EI help if you aren't logged in to help. Regards, Peter
Elizabeth Wheeler
Thanks, @Peter Jessen  can you specify "Align's help"? A URL would be helpful.
Peter Jessen
November 10, 2022
Hi @Elizabeth Wheeler -
The Help under the User Menu, as well as the Help button in the lower right of each page can take you to Jira Align's Help site https://help.jiraalign.com/hc/en-us.
You won't see the EI help until you login to the Help site. It is in Zendesk and distinct from the rest of Jira Align.
Peter
