Features: I can't change columns when having more than one Program
Thomas Petite
May 9, 2022 edited
Hi. We use multiple programs and we use Features. I can't change columns when having more than one Program.
When more than one program, JA defaults to its standard columns and you can't change them.
Why? Is this configurable?
This is the Jira Align: Features screen
Christoph Piotrowski [catworkx]
Hi @Thomas Petite , just a point, that might give a first help: as far as I remember, this message appears, if you select programs from different Portfolios. You should be able to adjust the columns, if your programs are within the same Portfolio. I assume the default columns is applied at a multi Portfolio context to prevent showing data that needs Portfolio-specific interpretation and should not be mixed up by showing it in one list.
Thomas Petite
May 11, 2022
Hi @Christoph Piotrowski [catworkx] , thanks for the response but there are default fields across portfolios. I would expect to at least be able to choose those fields to view.
