×Hi Team
When I attempt to view Group Dependencies in the Wheel view Map I cannot see any details in the Dependencies Overview frame.
If I view the same Dependencies in the Matrix view I can see the Dependency details in the Dependencies Overview frame
Is this a Bug?
Darren
Darren,
Could you possibly upload a screen shot of what you are seeing or not seeing? Also, is "Group" a platform terminology you changed in your environment from something like Program? More context may help.
Tom
I now understand what you mean by Group. Check your Tier 1 filters as I mentioned in your other post.
Confirm taxonomy
Group = Program
Team Map view is OK
Group Map Matrix view is OK
Group Map Wheel view is FAIL
Looks like it is a bug as well. I suggest submitting a support case so that our support engineers can review it to determine next steps.
Thanks for providing the details.
FYI: Previous bug report https://jira.atlassian.com/browse/JIRAALIGN-985 closed and fix due in version 10.65
