How do I delete a Checklist?
Gyanendra K Gupta
December 10, 2020 edited
I am working on Checklists and have created some checklists that I would like to delete. Can you help me with that please?  Thank you.
2 accepted
Jesse Pearlman
December 10, 2020
If you own the checklist you can delete it from the Checklist record by editing the Checklist after activation
robert.nadon
Click on Checklist from the Program room in the top right. Looks like thisScreen Shot 2020-12-10 at 10.14.50 AM.png
Select the checklist you are interested in, it will appear at the bottom of the screen.
Then edit the checklist.
When editing you will see "Delete Checklist"
Mark Cruth
December 10, 2020
Adding onto Robert's answer - enter into the edit screen of a checklist and you'll see the Delete option on the right sideScreen Shot 2020-12-10 at 11.26.26 AM.png
Like • Rodrigo Cortez likes this
Mattz Operations
January 14, 2021
is it possible not all versions have a program room tab? I don't see it in my top right corner
Jesse Pearlman
January 14, 2021
Not all checklists are associated to rooms - or is this a slightly different question on the UI?
Rae Gibbs
December 10, 2020
@Gyanendra K Gupta I can help you with you that!  If you click on the checklist, you see a frame pop up down at the bottom of the screen.  When you hover over it, you will see an Edit option in the right hand corner of that frame.  Click on that.
It will then open the checklist and there will be a Delete Checklist option on the right.
You will only be able to delete checklists you have created unless you have the system role of Super Admin.
Gyanendra K Gupta
Thank you.
Like • Rae Gibbs likes this
Mike Goitein
The interface has changed slightly in the new navigation, and now looks like this in the upper-right:
If you're a Super Admin and get error messages around the checklist not being aligned to the proper Room or Portfolio, you can still hover over the bottom to reveal the "Edit" button as Rae mentions on the lower-right hand side.
