Sign up Log in
How to Link Dependencies to Feature?
Dominique Greene
I see there is an option to link a stories to Dependencies but is it possible to link the Feature that is housing the stories to the Dependency?
Thank you.
Atlassian Guru
Hey @Dominique Greene
here is Ahmet from catworkx.
Have you already checked out any dependencies you have created? I'm attaching an example below where you can see:
  1. assign any story to the dependency
  2. assign any feature to the dependency
In case you wanna understand Jira Align dependency concept, then @Tarun Sapra had already documented in a great explanation. Enjoy it:
https://community.atlassian.com/t5/Jira-Align-articles/Flow-of-Dependency-Management-in-Jira-Align/ba-p/1612693#:~:text=In%20Jira%20Align%20a%20dependency,and%20the%20negotiations%20starts%20again.
Warm regards,
Ahmet
Dominique Greene
Hi @Atlassian Guru  thank you for responding. Yes I saw that as an option but in my company we create our dependencies off of initiatives making it difficult to loop the Dependency back to the Feature. I am currently going by a shared Initiative to try to connect Dependency to Feature which is time consuming and going forward we are going to try to reference the dependency ID in the tags section but was curious to know why the option doesn't exist on the Initiative level. Thank you.
