When you are creating a "Roadmap" in Jira there is an option in your Roadmap Settings for "Color By" and if you use the "Health (Default)" option you can color code your epics within the roadmap. However, whenever you refresh the page or go out and come back it does not retain the color coding of that epic. Is there a way to always open your Roadmap and see the last color associated to the epic?
@Joshua The "Sync" button functions as a Save button, but with the addition of a popup window that allows you to specify what gets saved. Just make sure the "Health" box is checked.
@Joshua can you click the "Accept Answer" on this page? It will benefit other folks facing the same issue.
