I need a burndown chart for multiple epics
stephanie barlow
March 25, 2025
I am trying to put together an Epic Burndown chart that will show progress for multiple Epics. I have multiple Epics (each epics has multiple stories under it) under my one project in Jira that I want to see what their burndown is together. All I can find is a burndown per individual Epic. I would love to be able to roll them up into one burndown.
  • Is there a way to get a burn down across all Epics?
ahmet_kilic_catworkx_com March 27, 2025 edited
Hey @stephanie barlow
In case you're using Jira Reporting rather than Jira Align, then:
- It is limited to one epic only. You might not get multiple on a chart.
- Solution proposal might be either a custom-developed forge app or searching marketplace apps.
If you're using Jira Align, then @Allan Maxwell has already suggested it. See below.
Best wishes,
Ahmet Kilic
ESP Consultant
Allan Maxwell
March 26, 2025
stephanie barlow
March 27, 2025
Thank you Allan! We haven't migrated to Jira Align yet, but this makes me excited to do so! It is on the horizon for next quarter.
