×Currently it's possible in the OKR Hub/Tree to see the progress of an Objective by seeing progress of the Key Results and the progress of Accepted Work Items.
But, is there a graph anywhere that shows the progress of the Objective score itself?
"View Trends"
Thanks for the prompt response.
i could not see that for the Objective Score. Only for the Key Results.
How do I get to that view?
Hey Heidi,
Just expanding further on Allan's response.
There is no averaged-out graph of all key results in one trend line as far as I can see, but the classic objectives details panel has the 'View Trends' button that Allan mentioned. View Trends shows all key result trend lines separately but in one window, so you don't have to click on them one by one.
Please check the 'View Trends' button next to Key Results list in the classic details panel. You can get to the classic details panel by clicking on the ··· more options menu in the details panel and clicking Go back to legacy experience.
I also discussed a similar topic with one of our SAs a while ago, they mentioned that from use case perspective it doesn't make sense for there to be a graph that averages all key results together because it can potentially distort the health of the objective by hiding a critical key result that's lagging. It can be convenient to have it, but it can also be counterproductive. I would recommend double-checking with our SAs about this since this was some time ago.
