When I upload JIRAs using my CSV , The requirement explanations , which i put in as Points(bullets) or new lines , are not getting into the JIRA story created. It looks messed up.
I also tried using the markup in the description column but still no luck . So i end up correcting the alignments after the issues are imported into the JIRA board.
Any suggestions to overcome this issue.
Hi Lakshmi,
could you please provide snippet of your csv structure. And log files after CSV import? So that we can be on the same page to help you pragmatically :)
Best,
Ahmet Kilic
Enterprise Agility Consultant at catworkx
