Sign up Log in
PATCH customfield via REST
Mark Northcott
Hello all,
I am trying to run a REST API PATCH to update a Jira Align customfield with a new dropdown value, and I am having problems finding the correct format.
The GET returns the following
"customFields": [
      "customfield_90704": [
          "id": 198,
          "value": " High"
However, finding the correct JSON Patch is hard. I've tried lots including the following but nothing seems to work. I think the path is close but then it says the values are not valid. Is this the correct format for  nested values deriving their values from a dropdown?
"op": "replace",
"path": "/customfields/custom-field_90704/",
"value": {"id": "197", "value": "Very High"}
"op": "replace",
"path": "/customfields/0/customfield_90704/",
"value": {"id": 197,"value":"Very High"}
"op": "replace",
"path": "/customfields/:customfield_90704/",
"value": {"id": 197,"value": "Very High"}
Any help would be appreciated.
3 votes
Enio Marques Junior
September 12, 2022
Hi Mark! Please try using the payload below:
"op": "replace",
"path": "/customFields/0/customfield_90704/0/value",
"op": "replace",
"path": "/customFields/0/customfield_90704/0/id",
"value": 197
Enio
Mark Northcott
Thank you Enio, your solution worked perfectly.
I did get another solution from Atlassain but it came up with an error "Not all custom field are active"
        "op": "replace",
        "path": "customfields/0",
        "value":
            "customfield_90706":
                   "id": 183,
I thought it might be that the field was not active in that story but that was nto the problem ... but who cares, your solution worked :-)
Thanks again
Heidi Hendry
Came here looking for similar information on using API to fill the Epic Benefits tab "Case Development" fields.
The above wasn't quite working for me
Found this resource:
How to use PATCH on the Feature/Epic custom fields in the API v2 in Jira Align | Jira Align | Atlassian Documentation
It is important when you have lots of Custom fields, to run the editmeta to find out where in the Custom Fields array your particular custom fields are.
Hope this helps anyone else hunting for similar info.
Upcoming Jira Align Events
