Hi @manish a ,
there is "Capture" button on the top. See the screenshot below.
Basically, you may follow the steps below:
- Click on Capture
- Use Ctrl+P function or Command+P
I recommend you display only the required columns, otherwise, some of the columns will not be readable in the PDF downloaded.
I hope this helps.
Warm regards,
Ahmet
