×Hi.
In field management i am not able to find target start sprint and target end sprint in epic.
I want to sync these fields to jira but they are not not coming as an option. I can see other fields like blocked, capitalized, category, driver, epic points, mmf etc.
Manish
@manish a That is correct. The Target Start and Completion dates are available; however, the target start and completion sprint fields aren't available to be synched through the connector at this time. If this is something you would like, please open a Support ticket and Support can raise it as a Suggestion to our Product team.
Thanks Jennelle. In the support ticket creation i went to the enhancemetns however in the create ticket option i am not able to find jira align as an option. it has other products of atlassian. not sure if jira align is listed as a separate drop down. @Jennelle Stearns
@manish a When you go to Support, do the following:
Not finding your request in JAC? No problem, simply contact support to submit your new suggestion. From the support contact form select:
What can we help you with? → Technical issues and bugs
Which product is this for? → Jira Align
What type of technical request do you have? → I have a question for the technical support team
Fill out the rest of the form with your details and request.
Our dedicated team of support engineers will carefully evaluate and work with you to add your request to JAC. Your support ticket will be resolved and you will be provided with a link where you can track your JAC’s progress.
Here is the full article in regards to this process in case you are interested: https://community.atlassian.com/t5/Jira-Align-articles/New-steps-for-sharing-Jira-Align-product-suggestions/ba-p/2484888
