Announcing the ability to unlink previously used project keys for reuse
Hey everyone!
We’re pleased to announce that we’ve began rolling out a new feature which allows you to unlink previously used project keys. This means you’ll be able to release previous keys to be used in new projects.
Please note that any previously saved links/filters/queries referring to the old key will need to be updated as they will no longer re-direct once released.
You can find previously used keys in the Details section of Project settings (both company and team-managed projects are supported):
If you’ve had a chance to use this feature, we welcome any feedback or questions here!
Regards
Carol & the Atlassian Team
31 comments
Tom Haapanen
This is great news! It did take a long time but very happy to see that a solution is finally here! 👍
Like # people like this
Christoph Schaub
Seems to work for me. I did not reuse the keys right now, but finally could release them for future use.
Ajay
Nice to see the feature
Yatish Madhav
September 17, 2024
Thanks @Carol Low - very nice to see this is now available and gives us a bit more freedom.
I think, though, in an instance like ours with over 900 projects and in total, over 1000 project keys (current and previous), it would be really nice to see, and have the ability to replace, the old key usages prior to releasing them. Like you mention, any previously saved links/filters/queries referring to the old key will need to be updated - it would be great if these can be automatically updated, even with a confirm screen, to the current key!
Also, if a project is trashed and then permanently deleted, I would love to have saved links/filters/queries to all update/be removed as well instead of the "The value 'ABC' does not exist for the field 'project'." error
Thanks for this update, though!
Stuart Capel - London
September 17, 2024
Wow, I remember praying for this a long time ago. Amazing to see it live!
Tomislav Tobijas
September 17, 2024
Love this! Thanks for the update 🙌
JG Meillaud _
Brilliant!
Carol Low
September 18, 2024
@Yatish Madhav - thank you for the great feedback as always!
We hear you on managing previous keys at scale. We could potentially address existing filters but with things like URLs and queries it would be difficult to get full coverage (e.g. bookmarks in browsers, saved queries in notepad etc). Please feel free to keep sending more feedback as you use it.
Yatish Madhav
September 18, 2024
Thanks for the response @Carol Low  - i i very well understand that.
I think what Atlassian could control within the scope of a site like the filters, or links in existing issues, text fields, etc  where an old key is used, it would be awesome if those can be replaced and overcome as a starter ...
Thanks again.
M Amine
September 18, 2024
Great! It's very interesting
Rachael Williams
I am excited for this one!  I don't come across this need very often, but when I do run into conflicts with a previously used key, it's very frustrating.  With this change, I'm curious if there will be a way to easily search for previously used keys?
In one scenario, there was a project key that a team wanted to use but it was already taken.  However, I couldn't find any record of it.  It turns out that it was an alias of a project that was rekeyed at some point in it's life, so it was hogging up 2 names. I forget how I eventually figured it out.  With a new field "Previous Project Key" being rolled out, would all of the previous keys be searchable from the project list?
Dana Gleason
September 18, 2024
This is huge!
Robin Surland
September 18, 2024
Great news, however, is this something that admins have some control over? For example, we are bound by the rules of the FDIC and we need to maintain our documentation for five years. Will we be able to either set that rule (can't reuse keys for five years) or turn it off or limit use to specific groups?
Susan Waldrip
September 18, 2024
Thank you to you @Carol Low and your team for implementing this feature! A suggestion (isn't there always?): It would be really helpful to also display the project IDs on the Details screen to help clean up filters, automations, etc.
Anne Saunders
September 18, 2024
This is VERY cool, and the kind of new functionality I actually want!
Carol Low
September 18, 2024
@Robin Surland - This feature is admin only - will this control suffice for now? We don't have a separate permission for this, would love to know if you think there's a particular role that best aligns with this.
@Rachael Williams - That's a great suggestion - we'll look into it! In the meantime, if you try to re-use a key and it was previously/currently used, the error message will tell you the name of the project using it - hope that helps in not having to go through projects to find them!
@Susan Waldrip - just to make sure I understood, do you mean to show a list of previously used and deleted keys?
Susan Waldrip
September 19, 2024
Hi @Carol Low , your question actually brings up a better idea than mine! I meant add the new project ID to the Details page, but having a list somewhere of the old ones would be really helpful -- especially for admins to assume responsibility for other admins' projects and sites, quickly identifying previous projects by ID would help them understand what's been done in the past and even debug certain problems. Thanks for considering this!
Like Carol Low likes this
Kelly Arrey
September 23, 2024
Thanks Carol, this is awesome news!
Like Susan Waldrip likes this
Susan Waldrip
September 25, 2024
Hi @Carol Low , thanks for the update announcement! Is this feature only for Jira (software) cloud, or does it also apply to JSM cloud? I use the latter and haven't seen it, so if it's only for JSW right now, will it be implemented in JSM? Thank you!
sara
September 26, 2024
@Carol Low & team: has this feature been rolled back? I had it earlier this week but it seems to have disappeared now...
Carol Low
September 26, 2024
Hey @sara and @Susan Waldrip
We've encountered a few edge cases for JSM which need a bit more work to support, and have temporarily rolled it back.
The feature will be back on following our deployment schedules shortly for Jira projects, and thank you in advance for your patience on JSM projects while we sort out the kinks.
Kelly Arrey
September 27, 2024
Thanks for the update @Carol Low.
As an aside, where do JPD projects fit into this? Thanks
Kel
Carol Low
September 29, 2024
@Kelly Arrey JPD will also be re-enabled shortly!
Wendy Imfeld
October 3, 2024
Hi Carol
Happy to read about it - but I would need it right now for a customer.
Would it be possible to get in touch with me- regarding this function ?
best regards
Wendy
Tobias Viehweger
Hi @Carol Low
Thanks for sharing. As a Marketplace vendor, I wonder what this announcement might have for implications for our App, especially when reading this line:
This seems to imply that at the point in time when a project key is released, all existing references will stop working (e.g. in stored JQL queries, issue keys?). Would that also affect the normal REST APIs for example?
CC @Ian Buchanan [ianbuchanan]
Tobias
