How to make “Story points” appear on issues?
Hello everyone,
I’m Carol, product manager here at Atlassian looking at issues and fields configurations in Jira Cloud.
One of the questions we often get is: “I’ve added the “Story points” field to the issue layout/screen, why don’t “Story points” show up on the issue view for some issue types?”
Before I dive into the solution, I’d like to set the context with some concepts to explain the behaviour.
There are multiple settings that determine whether a field is visible in the issue:
  1. Associating the field with the screen
  2. Associating the field with projects/issue types through field contexts
  3. Showing/Hiding a field using field configuration schemes
  4. Adding the field to the issue layout (affects Issue View only)
Why does “Story points” field not appear on issues?
The most common reason for the “Story points” field not showing up is because of the field context that is associated with the field.
By default, the “Story points” fields is available only for issues of the following issue types:
  • Story
  • Epic
If you want “Story points” to show up for other issue types, you can configure the field with the steps below:
Configure the context for “Story points” field for issue types
Note: To make the following changes you will need to have site administration permissions. See Permissions overview for more information.
To change the default, you’ll have to associate the “Story points” field with other issue types. To do so:
  1. Go to Settings (Screen Shot 2022-03-30 at 5.56.28 pm.png) > Issues > Custom fields.
  2. Select Story points field > Contexts.
  3. Select Create, edit or delete contexts > Edit context.
  4. Select Any issue type to make the field available for all issue types. You can also select only those issue types you want this field to show up for.
The “Story points” field will show up on the issues after you’ve done this. If you find that the context is already configured for the relevant issue type(s), please have a look at the other settings mentioned at the start of the post to diagnose why it is not appearing.
Hope this helps. Feel free to comment below for any other details.
11 comments
Elke Heinrichs
Thank you Carol, for this very usefull explanaition. Regards, Elke
Like Carol Low likes this
Erick Miranda Márquez
Awesome tutorial! Many thanks for sharing your experience with us.
All My Best
Taranjeet Singh
March 30, 2022
@Carol Low Thanks for sharing this article! Being an Atlassian consultant and/or admin since last 6 years, I know that this is a common complaint from a lot of users using "Story Points" field for their issue types in Jira, and you have correctly documented the solution that I provide for this issue.
This is going to be super useful for any new Jira Cloud Admins here!
Like # people like this
Dave Mathijs
March 31, 2022
Thanks for clarifying that the context of Story Points is by default limited to issue types Epic and Story, wasn't aware either.
Sri Kumar
April 1, 2022
Thanks for writing and sharing @Carol Low
Jan Verbeke April 20, 2023
I do see the story point field on the story issue type, but I can't edit it, although it's on the edit screenlayout.
Like josh.sutterfield likes this
Agnieszka Kornas
July 7, 2023
I have more basic issue.
I can't add Story Point to User Story.
I am a project admin.
I go to issue types, chose Story and I want to add "Story Points" but I can't see it in the right menu.
I try with advanced but I can see Story Point but can't add it either.
I am using default screen scheme for this project. And this scheme contains the screen
Karen Bottai
Im glad I ran across this article. I was perplexed why all the rest of the projects could have Story Points but one did not. turns out it was not added in the default section of the context. Thanks for the article!
George Grigorian December 29, 2023
Thank you so much! This was perfect and to the point. Happy Holidays!
josh.sutterfield
There doesn't seem to be "Custom Fields" in my case, only "Fields". Story Points is there but nothing is editable and there is no "Contexts". Just a table listing all the fields. Story Points says "5 screens" but I have no idea what "screens" these are since some fields indicate huge numbers, like "39 screens".
Like Johannes Trame likes this
Shaunty
This isn't working. I've read every article, and checked every stupid configuration. I have one single project where story points will not show up in the backlog.
I'm about ready to throw my computer out of the window because this is ridiculous.
Like Erin Mills likes this
