Hello
I have a field as a string, which contains a number (Yes i know... i didnt create it :x)
In the filter i want to create, i need to order the result by this field.
Something like this :
project = MyProject AND resolution IS empty ORDER BY stringField
"stringField" is the field i want to cast as a number.
This field contains number like : 1, 2, 3, ..., 10, 11, ..., 40, 41, ...
Jira orders it like this : 1, 10, 11, 12, 13, ..., 2, 21, 22, 23, ...
I tried few ways founded in Google, but nothing worked for me.
Can anyone would be able to help me ?
Bear in mind that workarounds generally will be a pain in the neck in the future. So, it would be wise to create a number field and copy the values from the text field (if it is not too late).
Other benefits of this suggestion are (once you're satisfied that all instances have been successfully converted):
This should prevent "illegal" entries, such as alphanumeric entries where only numbers should be allowed.
Prevent "whitespace" in the field. (This can be troublesome if sharing data. A string "number" with whitespace after it may not be treated as equal to that same string "number" with no whitespace after it).
These are just two benefits that I can think of that should weigh in the decision of creating a new number field, like Tuncay Sunturk_Snapbytes_ described.
If for some reason you want to keep your String field, and if you run scriptrunner, create a (numeric) scripted field that shows the contents of your string-field in number format. Ordering on that field will behave as expected...
One other thing to try, if you add a leading 0 to the single digit numbers i.e. 01, 02, ... 09 that may get around the issue.
But as far as I understand this is not a field for only two-digit numbers.
String sort will be done as below:
Hi i Found some old answer from the top activity leader @Nic Brough -Adaptavist- ,
If the string field is an text field , sorting may not work properly.
If The string Field is an Numeric field , there is a chance of displaying results correct order.
If the string field is numeric , and sorting not worked, and you are using "Jira Server". you can re-index the Jira. this will helps you.
I agree that a new numeric field is the best solution. There are two ways to go forward:
1. Create the new field, run some automation/scripting on all existing issues to bulk-copy the old field to the new one, then modify the new-issue/edit-issue screens to hide the old field and show only the new one. Basically, you're deprecating the old field (if it's mandatory, make it not so).
2. Add the new field, hide it, add some automation to populate the new one whenever a new issue is created or when an existing issue gets updated - you can do it with an event listener.
My preference - option 1 - let bygones be bygones :-)
Hi @Baris TEKELI -- Welcome to the Atlassian Community!
In addition to the other suggestions...
How many times do you need to sort the information in this way, and does the result need to stay inside of Jira for follow-up actions?
Best regards,
Hello, and thank you so much for your answers !
I read your answers and noticed that I was not clear enough.
Few details :
This is why I'm trying to convert this String field into a number one.
The best way i found so far is to create many filter result in my board.
I still order by this stringField, but i added a condition to take the stringField ten by ten :
And the condition is like this (for the filter 1) :
stringField ~ "1 OR 2 OR 3 OR 4 OR 5 OR 6 OR 7 OR 8 OR 9" ORDER BY stringField DESC
Waiting to found how to convert the stringField, if it's possible, or waiting to get my rights to do it myselft. (or create a new field).
Thank you again for your answers !
Hmm even though I do not recommend, you can bulk update these issues adding leading zeros as Warren mentioned.
then you can use sorting.
I can see that it's a good solution.
But how exactly do i add a leading 0 only for 2 digits, and two 0 for 1 digits ?
And then, how do i sort according to this ?
You can do that programmatically. If you have Script Runner you can easily code a few lines and do the bulk update.
I can help you on this code but as I mentioned before this is dirty workaround, the best is to use number field.
Cheers
Thank you @Tuncay Senturk
The code is not a problem.
The problem is that I dont have Script Runner, and I tried to do it via JQL Filter (lol)
I know that the best way is to create a new field, or change the existing one. I'll try this way with my organisation. Hopefully, they will understand my need.
Not to digress from the topic here, but if I had one single Add-On to purchase for Jira, it would be Script Runner. You'll find a LOT of solutions offered refer to running a script to do something and it's the best tool for doing that. It also has a lot of built-in tools and scripts that allow you to perform many Administrative tasks.
I'm not a Script Runner salesman, just a Jira administrator like you who has to address a lot of users who want Jira to do this or that...
Good Luck!
I wholeheartedly support what @Chris Annal said above. I am also not receiving any commission from Adaptavist :-).
To me, ScriptRunner has proven itself in at least two categories:
1. Provide solutions to problems that Atlassian should have but never did. An example is the built-in script to bulk-import custom field values (for single/cascaded selection list fields) and the bulk resolution setter.
2. Save you a lot of manual work and/or Java programming. A great example is the event listeners.
Be aware that that there are other add-ons that provide multiple capabilities, such as JMWE and JEP.
@Baris TEKELI I cannot tell from the posts if you are using the Cloud or Server version...In either case...
I you plan to leave the text field in place, and people can continue to edit the field...
Have you considered using a simple automation rule to automatically left-pad the field with zeros? Then a simple string sort will work.
For example:
{{issue.stringField.leftPad(3, "0")}}
To learn more about automation rules please look here:
https://www.atlassian.com/software/jira/automation-template-library#/label/all/1453
Hi @Baris TEKELI ,
Provided that you would like to use such a number as a score for priority, I'd suggest using Jira Software's Rank native feature.
Rank is an alphanumeric field (it effectively works as a number) for convenient reasons (ability to represent really large numbers).
Besides, it also solves the problem of reordering issues with ease (Rank's multiselect + drag & drop VS multiple manual issue editions of a number field).
That said, regarding a method for setting a number field with the content of a text field, I would suggest exporting the issues to CSV through the Issue Navigator, with the following columns: Key, Summary, <Your Scoring Text Field>. After that, the Jira Administrators CSV import feature might be used to update said issues, provided that mapping the issue key of existing issues updates those issues instead of creating new issues. During the import wizard, map issuekey with issuekey, summary with summary and <Your Scoring Text Field> with a number field.
Hope it helps.
Indeed, this could also help !
I'll try to use your suggestion in another issue, since the one in this post is solved.
Hi everyone,
I have been able to get a numeric field from my organisation. The text field is no longer used. So i can filter properly with numbers, as @Tuncay Senturk first said.
And it works fine.
So now, i'ldlike to close/solve this post, but I don't know how..
Again, thank you all for your help !
You just need to accept the answer :)
Recommended Learning For You
Level up your skills with Atlassian learning
Learning Path
Become an effective Jira admin
Manage global settings and shared configurations called schemes to achieve goals more quickly.
Streamline Jira administration with effective governance
Improve how you administer and maintain Jira and minimize clutter for users and administrators.
Learning Path
Become an effective Jira software project admin
Set up software projects and configure tools and agile boards to meet your team's needs.
