We are using Jira as our work management tool. We are working with a vendor for some custom development, and they are also using Jira as their work management tool. There are times when work on our end is held up by work from the vendors end. Is there a way or a tool that can somehow link the 2 projects from different organizations to show a dependency report?
Solved! Go to Solution.
Hi @Coby Fuller
I recommend first pausing to review your statement of work (SOW), or other information, with the vendor to learn how you both planned to keep aligned on status.
There appear to be apps in the marketplace to do this type of synch, and I have not used any of them so I have no recommendations: https://marketplace.atlassian.com/search They may do more than what you are asking to achieve, and the vendor may not want to allow it (e.g. due to other clients information).
So, technically, yes, you can link two Jira Cloud instances together. @Ravi Sagar _Sparxsys_ has a good demo: https://www.youtube.com/watch?v=7-oq-X8uVtU
It's basically a good old Application Link: https://support.atlassian.com/jira-cloud-administration/docs/use-applinks-to-link-to-atlassian-products/
The CATCH, of course, is authentication. Will you have accounts on your vendor's Jira instance? If they've granted you limited access to a specific project in their instance, then I think this could conceivably work.
For this, you're very likely going to need OAuth authentcation without impersonation. (Since your Jira instance will not have the same userbase as the vendor's)
If you are able to connect this up, anybody looking at one of your Jira issues with links in the Vendor's Jira would likely not be able to see status, etc. without also having valid accounts on the vendor's Jira.
Thank you @Darryl Lee Exactly what I was looking for. This helps at least create the connection and teammates on both ends can maintain the dependency links. I can then create reports outside of Jira to share with the rest of the teams on both sides.
It did work. We have 2 teammates from each organization that meet once a week and will work through the dependency links. Once the links are in place, even though some teammates will not have access to the other's Jira instance, they can still see the issue key for the linked dependency. I will create a Power BI report to share the with teammates to also help show the dependencies between the organizations once the links are in place.
Recommended Learning For You
Level up your skills with Atlassian learning
Learning Path
Become an effective Jira admin
Manage global settings and shared configurations called schemes to achieve goals more quickly.
Streamline Jira administration with effective governance
Improve how you administer and maintain Jira and minimize clutter for users and administrators.
Learning Path
Become an effective Jira software project admin
Set up software projects and configure tools and agile boards to meet your team's needs.
